Saito FG-60R3
#2276
You have probably saved your engines just by doing the timing adjustment, but it will likely mean you dont get the best performance out of them, for that, the timing needs to be around 35-39 degrees from what I can deduce....but I am not one to seek performance over reliability...I will go with the latter. The problem is that the ignition curve is SET to advance to a max of 28-30De BTDC and a minimum of around 4-5Deg BTDC for starting. This means that to get 35-39 BTDC, the entire curve has to be shifted and then you get pre-ignition occuring in mid-range, and great power at the top end.... If the curve went from 4-5Deg on starting, all the way up to 35-39 deg, there would be a good range for easy starting, transition and top rpm.. At the moment, there is a compromise....
JM
#2277
This is one of the older RCxel curves. Please note this is not from an official source, and if it is under copyright, I will happily remove if it caises problems.
It seems that the clever electronics in the chip, along with the presence of the 'check' magnet can figure out that the engine is at low/start revs, and retard the ignition to around 4 Deg, then at around 1500rpm-2000rpm, it starts up towards 28Deg and then advances no further after 4000rpm. Considering, most of us are getting around 6250-6500 static, which probably unloads to around 7000rpm, the timing is not advancing at all where the power should be. This is why Saito (and others) have said best performance is with the timing around 35deg. The problem is that you have to shift the ENTIRE curve, and then at low(er) rpm ranges the timing is suddenly SO advanced that it starts the pre-ignition problem, and THIS is where the damage is taking place as the engine doesnt have the inertia of the higher rpms, and the gas is ingited very early causing LARGER pressures in the combustion chamber, and the exploding gases are now competing with a rising piston....
This is just MY THEORY, but if the upper end of this curve could be set at 34 degrees instead of 28, we would probbaly get the best of both worlds...
#2278
Clogged needle!
When you say you looked at the HS needle, do you mean you were looking it from the side where the rotating barrel goes into the carb? If so, when you look there, and have the HS needle out, then you should see all the way through the brass tube that the HS needle goes into? (The same tube that has the slit in it, that the LS needle goes over?) If so, then I think I might have had the same trouble with mine at some stage, and I thought I had broken something so bought a new throttle body... probably coulda cleaned that out but I was too nervous to as I didnt want to pokey-pokey inside there...
As Ed says, I have a felt clunk in the bottom of my fuel can, I also have an inline filter on the filler pipe. I also ONLY use felt clunks in the planes fuel tank. Some have tried putting inline filters between the tank and the carb, but everytime I have done that, it seems to be a source of foaming so I avoid by have the other three filters in place....that should be enough. I prefer seeing the line from the tank to the carb with NO bubbles or air pockets in them.
yes, that is exactly it! Looking from the rotating throttle barrel side, I could not see all the way through when the high speed needle was out. I ran a jewelers drill bit through it and it poked whatever was in it out. I have the rotofkow tank with the auxiliary filter system and don’t know how it got in there but it did. The motor runs perfect now and getting ready to fly the p47 at warbird event at the end of the month. I’m not going to do any timing mods on my engine or anything else for that matter, it just runs too good. It will idle around 1,000 rpm and hit 6100 on a 23x10 prop. I’m 6.5 out on the low needle and 2 turns out on the high. I have a little room to lean it out when the motor gets some time on it. I sure appreciate all the work and expertise that people are sharing about this engine though! I hope everyone enjoys them and gets good service with them.
How long does the warranty last on these engines? 1 year? mine is the latest version with the new pistons and cylinders so hope it last. Sure runs great and sounds good with the Kelo exhaust.
#2279
Smother, thanks for the update. I am going to have a look at my carb and see if there is anything odd going on in there. As I say, I bought a new throttle body because I thought I had broken it, but it would be nice to have a spare, functional carb that I can install quickly should the need arise, and then I have another to recondition and keep spare.
I think the warranty is a year, from date of purchase. So best to get it run in, and use it, if its going to dismantle itself, it might do it sooner rather than later...lol. I had a guy come by the field yesterday, and he was very unhappy as his brand new FG84, which he had spent hours meticulously running in, went on its maiden and siezed in-flight. He managed to get the plane down without too much damage, but the engine was totalled....from the pics he had, looks like the main crank bearing failed. The Fg84 did not have the bronze bushing, so might have been that. he was quite fastidious with his prep, so doubt it was any fault of his own. Unfortunately, he bought his years ago, and has only recently managed to get it in the plane he was building, and as a result, no warranty whatsoever.
If your has all the new gubbins, you will hopefully be free of troubles. It would be interesting to see if they have made any changes to the timing... the new pistons will result in lower compression, and the new cylinders have more 'meat' on the mounting areas so should not be prone to cracking as easily....I wish you all the best of luck!
As for Frankensaito, we did 2 more great flights yesterday, the ambient temps were in the low/mid 40Deg C,so really warm, and that was at sunset! We have put the cowl back on, and the last 2 flights the temps were getting up into mid 170C, which is high...so we removed the fake exhaust stacks from either side of the fuse, and this opened up the cowl with 2 large exits, that are placed in such away that they create negative pressure and draw air out. Big difference. Highest temp recorded yesterday was 162C, its still a little high, but that was only for a short burst...mostly hanging around 150C for most of the flight. Where we did the opening cowl mods, after the flight, with the nose pointed into the wind, you could feel a lot of warm air being removed by the wind, so it is definately doing the cooling job.
Again, very very economical engine, got 2 x8 min flights and there was probably enough in a 500ml tank to secure you 3 x 7min flights.
Here are a few vids....again, sorry for the wind noise, and the light was getting low so quality is down....
#2281
Actually looked a little worse than that. I didn’t take too much time to examine it but that lower left pin that’s hanging off in your pic, had sheared fully and he said that the piston had actually jettisoned off into the valves and smashed into the valves. Complete write off according to him.
its the 3rd one that I have seen amongst my peers here, and all of them appear to have had similar causes. I am making an assumption in that but if you had to press me for a reason, it would be a seizure of the main crank bearing. Yours looks to be the same. Would you agree or do you think it could have been something else?
To me, it’s lack of lubrication on two surfaces not fit for purpose, gets hot, shears off through material failure on overheating. I could be wrong though.
#2284
As far as I know, they aren’t sold separately, you’d probably have to buy a whole new ignition..
i think I got a respons drone RC-Japan and HH that they aren’t available.
i made one out of the inner wire of a heavy gauge, a-string inner core of a bass guitar string 😄
#2285
#2286
Your lesson?
thats an FG90? Wow, so they also have a lesson in them then. I agree, 4T engines are not like 2T, they prefer the lower revs, higher torque applications.
The FG60 prop size is said to be a 22x10, and I have seen guys thumping them through the air at a rapid clip in that size, but ever since messing with the 4-blade combo, I have realised that revs are t everything with these engines. I have noted that Didier is flying his bearcat on a 21x12 (or something like that) and it seems to like that too!
I wonder if running the negative crank mod might have saved that engine?!?!
#2288
Your lesson?
#2289
Forces, was that YOUR engine that disintegrated? If so, sorry to hear it, but yeah, too high revs will do that.
one of the guys at our field has the FG19R3 and he had a prop that was at the lower end of the specified props and he was getting 10,000+ rpm out of it! It sounded like an angry was and the prop tips were going supersonic... I recommended he go up in pitch and since then it sounds better and pulls nicely.
there are too many moving parts here to hit those rev ranges imo..
#2290
Hello,
I regularly read this forum, but this is my first intervention to share my experience.
You can see on this graph the engine RPM on the ground and during the flight with a Mejzlik 22 x 10 :
6350 RPM on ground and more than 7300 during the flight. Is it too much ?
My engine is an FG 60-R3 on which I moved the magnets of the original propeller hub to have 30 degrees BTCD on each cylinder
#2292
I dont know if the revs you are getting is going to torch your engine, but it might be a good idea to try something with a little more pitch, and see what happens. I see there are limited vendors of 22x21, but there are a few, maybe worth trying them out and see what the handling is like, and the revs.
We dont have a rev counter on our test plane, well we do, but its onboard only and doesnt store revs, so I cannot tell you what revs we are getting in flight. I know that it does around 5400-5500 on the ground, and is quite happy doing so. As mentioned before, these engines are 4T and they like a little more pitch....
I dont know about rev limiters saving engines, but from my deduction, Saito are trying to squeeze as much 'power' out of these engines as they can, as the 'popular' perception is that more revs is better....hence the aggressive advancement on the timing from factory....
Just by the way, those videos I put up, the takeoff on that plane is always at about half throttle, for the simple reason is that the inboard gear doors dont close properly at speed, so the take off is slow, no flaps and then when the wheels are tucked away safely, the throttle goes up. We are fortunate that we have a nice long runway to do that with, and understand why some would want more grunt on take off.
#2293
I have a Saito FG R33 which went into self destruct after running in and a couple of flights. Morris Mini Motors completely rebuilt the engine with all the mods and now runs a lot better. It seems there is a common fault in all of Saito radials, I never contacted Mcgregor Industries in England regarding the problems as I have had dealings with them before. My engine is installed in a 1/4 scale Sopwith Pup but around half throttle it ran like it sounded rich, I managed to find out that due to atmospherics within the cowl it would upset the carb and to overcome this I removed the plate on top of the carb where their is a small hole which I drilled out and tapped a 2mm hole and installed an exhaust nipple I then attached some fuel tube and drilled a 3mm hole in the top and bottom of a 35mm film canister thus sucking in smooth air, the canister is placed within the fuselage. This trick as been around for a long while.
#2294
Its not so much a common fault, its just that Saito thought that converting engines designed for glow, is as simple as adding an ignition system, and changing the carb, and hey presto! New line of gas engines.. It is not impossible that it could work, as many people are doing the conversion of glow engines by getting new carbs, ignition systems and doing it successfully. The biggest differences being that they need to have a higer than normal fuelil ratio than gas engines normally have. In most cases, this is 20:1 as opposed to 2T engines that are running 30:1, 40:1 and in some cases, successfully on 50:1. The reason is that there is no lubrication APART from what blows by the piston rings. In theory, there is nothing wrong with this, and it seems to work in many cases BUT it also means that many engines are getting a lot of carbon build up on the valves (exhaust mainly) and in the combustion chamber. The engines are NOT able to burn off all the oil as they NEED excess oil to blow by. Problem is, most of these oils are going past the HOT exhaust, and sticking to it, causing build up.
I have been looking into some 4T engines that have been designed from the ground up, as gas engines. One of them is the NGH range. The NGH38 is an interesting one, it has a series of breather pipes from the backplate to the carb and inlet manifold. They seem to be using crankcase pressure to run the carb, and distribute oil/vapour. They seem to run well and apart from a few cases of badly worn cam lobes, they seem to have operated well. Some have even admitted that they 'may' have underpropped/over-revved them which has caused valve bounce and the resulting cam wear.....NGH suggest 32:1 oil ratio for these engines.
The UMS gas radials are ALL using the crankcase to distribute fuel air mix, and they are all specified at around 30:1. They are fairly new, and not many people run them, so longevity is questionable. I know nothing about quality of materials in these, but they look great, and they have a nice range of sizes too, this will be my next radial.
The OS GF40 single gas 4T has a PCV valve type set-up that is what is regulating their lubrication, and is using crafty methods of getting the oil around the engine, and apart from one or two cases of excessive valve train wear, they seem to be good engines. The ones that have had wear problems on the rocker shafts, have cured this by avoiding over-revving. Apparently the PCV valve (ball and spring thing) was not able to open/close properly at high reves, and lubrication ability went down....result: engine wear and failure.
Saito have their radials, and they also have the single gassers (I have the FG40). The singles, like the radials, DO NOT have any method of lube APART from blow by and ALL of them require 20:1 oil. The singles do not appear to have the failure rate, and seem to be quite reliable.....and here is the kicker in my opinion... The singles are all timed around 28-30Deg BTDC....the radials at 44 Deg BTDC.....WHY?......WHY? ....WHY? The ignitions ALL run the same curve..... my guess is that they are constantly trying to appease the masses that demand MORE POWER, MORE POWER, MORE POWER.....theyre getting it, but they are also getting failures.
I have not looked at the Valach Engines, Kolm Engines, Laser, Roto or Moki Singles but from what I can see on their pics, all of them seem to employ either a breather pipe setup such as the NGH setup, or they are connected to the inlet somehow. I dont want to speculate on their engines, but it seems to add up to me, that lubrication is a problem, ignition timing is a problem on the Saito's. Over-revving is also going to contribute, especially if its timed wrong, and badly lubed.....although even if those to conditions are met adequately, I would not want to run the revs too high anyway....
All speculation, but it seems to add up. Some people cannot believe that the awesome people at Saito would make such a glaring error, and will stand by the expertise of Saito. I understand this and hope your engines last....
- UMS engines, timed at 30DegBTDC, with crankcase lube @30:1 oil ratio
- NGH engines, cranklube through breathers @30:1 oil ratio. Strangely, they time this at 40Deg BTDC from factory, but everyone running them has changed this to around 30-35Deg BTDC and they run better.
- OS engines,crankcase lube through PCV setup, timed at 30DegBTDC @30:1 ratio
- Saito Singles, timed at 30DegBTDC, blowby lube @20:1
- Saito Radials, timed at 44Deg BTDC, blowby lube @ 20:1
- FrankenSaito, timed at 30Deg BTDC, crankcase distribution lube @ 30:1
#2296
No mate, you’ll need to speak to Morris at Morris Mini Motors if you want to do that.
The new motors come with new cylinders and pistons and I would expect they will be more reliable but I don’t think they have made any other changes.
#2297
For your information Olivier Rogeau (Modelisme Micromoteurs Service) makes some tests with a needle bearing on the master rod. This guy is a French craftman who also makes intake modification on the Saito (and other) radial series. He is very active on Facebook and is english speaking. He has also a web site (unfortunatly only in French)
A picture of his main rod modification.
JM
JM
#2298
FL
I wonder if it is all the heat build up ins cowls causing problems. If it was on a a stick where it stays nice and cool. It would hold up better.
#2299
Overheating IS potentially going to be a factor, as will over-revvving, but they have let go in conditions where they were fine and still came to grief.....
out in the open air, will help keep it cool for sure...but not going to stop ignition advance and lube factors.
who knows, maybe you’ll get a life time of good service from yours. I hope so!
JieM, I hooked up with his FB page, he does some interesting stuff, quite an entertaining dude :-)
#2300
FL
