Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
No.. could it be..?
No.. could it be..?
Old 01-24-2015, 01:46 PM
  #51
MJD
MJD's Avatar
Originally Posted by Rudeboy
I'm definitely not in a hurry.
I can live with a short kit, but would prefer a more complete pile of wood, since the plane is designed for imperial sized wood and thus I would have to special order a bunch of imperial sized wood to finish a short kit properly. Sanding down a trailing edge stock to fit is one thing, but sanding down a bunch of sheeting is another matter
What are your standard balsa thicknesses? The only remotely important dimension is sheeting thickness, and if you only had 2mm for example, then use that - perfect!
Old 01-24-2015, 02:08 PM
  #52
Rudeboy
Rudeboy's Avatar
1 / 1.5 / 2 / 2.5 / 3 / 4 / 5 / 6 / 8 / 10 / 12 / 15 / 20 / 30 millimeters
The sheeting is actually the least of my worries, but I'd hate messing up a set of perfectly laser cut formers with loose fitting spars and what not.
Like I said, I can work around it, and it really isn't a big deal. But a full kit is just easier.
Old 01-24-2015, 02:37 PM
  #53
iron eagel
iron eagel's Avatar
All you really need from the kit is the spars and formers and you good to go, if sheathing is no problem for you to get.
If your going for "real speed" go with a single fin rather than the dual fins or wingletts on this one.
Old 01-24-2015, 06:50 PM
  #54
MJD
MJD's Avatar
Yeah I'll include the CF spars, I have lots of those. 1.5mm - 1/16" sheeting, fins 3mm or whatever you prefer. Won't have full kits for a while.
Old 01-24-2015, 06:54 PM
  #55
Rudeboy
Rudeboy's Avatar
Works for me.
Old 01-25-2015, 03:09 PM
  #56
MJD
MJD's Avatar
This was earlier, I am cutting sets of ribs 1&2 now. Rib 1 is about 21.5" long and my X limit is 20".. so I cut them separately on the diagonal.
https://www.youtube.com/watch?v=vXX1sLCwPk0
Old 01-25-2015, 06:11 PM
  #57
smoknrv4
smoknrv4's Avatar
I can smell it from here! Cool man!
Old 01-25-2015, 06:47 PM
  #58
MJD
MJD's Avatar
I was so eager to start cutting, I had everything all set but the last detail - deck height. I had only eyeballed it, so the head was about .150" too far, with only a short focal length (1.5") lens. That's why it is cutting fat there, but the parts one that sheet are off by all of maybe 3 thou.. oh no!
I have all ribs 1,2,3 cut so far, two sheets of rib 4, the tip rib now. One almost done. I smell like a sugar shack from hovering around the filter exhaust all afternoon. (no worries, big HEPA filter and activated carbon organic vapour filter. Just a sweet burny smell.) Ah, done. 16 tip ribs, 5:54.
Old 01-26-2015, 06:33 PM
  #59
MJD
MJD's Avatar
Got all the short kit ribs cut yesterday, just cut the 1/16" ply bulkheads, next... the Motor Plates.
Guys, this is easy to do for this handful of 5 people/8 short kits, I'd be happy to cut the motor mounts to fit the engine. I saw some of these will get Jetts, so those are the rather common OS .46 beam mount pattern. I have a SJ .50 and an OS .46 on the table in front of me with the caliper to double check. Now.. .32SX mounting, that is easy to find on the OS site. Anyone mounting a big block - you'll be improvising a bit, I can include a couple of spare ply center ribs, motor plates, and CF spar material. I will PM y'all shortly on this, we can swap info there.
Old 01-26-2015, 06:43 PM
  #60
Bonified Wingnut
Bonified Wingnut's Avatar
I am not sure about what engine if you are selling me one. I have 2 Novarossi's , an R528F and an R50F that I would like to try. Since I am not familiar with the plane I might need a recommendation on which one.
Old 01-26-2015, 07:05 PM
  #61
MJD
MJD's Avatar
You're on my list!
Definitely the R50F, perfect engine for it. I'll bet an APC 9-8 is close to the best prop for the combo. Stubby 8oz tank if you can. If that engine lives up to the name, you should have yourself a brisk machine.
The T528F would be ideal on a smaller airframe, it will need a prop like the Graupner 6.5x6.5 or something in that range to get up where it sings. I'm working on a 26" span Demon.. that would be perfect.. prototype did 161 mph on an OS .25 VF-DF & 6-6.
Old 01-27-2015, 05:16 AM
  #62
Bonified Wingnut
Yeah I think the R50F is more of a sport engine but it seems to run good. Have not found much info on any of the Novarossis. I think I need a shorter pipe for it. I don't remember what I was getting 15k or 16k with a 10x6 and a long muffled tuned pipe. I didn't get much time to mess with it last year before winter arrived. I would like to get the R46F pylon engine but it is a little out of my budget right now. But I think a 9x8 does sound like a good prop for it.
The R28F I was getting over 18,000 with an 8x6, but I only ran it once and have not tested the 6.5x6 or 6.5x6.5 I have.
Old 01-27-2015, 05:58 AM
  #63
MJD
MJD's Avatar
18k on the 8x6 is getting there, for reference I have seen 18.2 on the same prop from a piped GMS .32. I think you're on the low side of that engine's timing based on the specs, will be interesting to see how it responds on the smaller props.
Old 01-27-2015, 06:54 AM
  #64
Bonified Wingnut
Yeah I have only ran maybe 5 oz of fuel through it. I have a Gms 32 and have never tried a smaller prop on it. I usually run a 10x5 or 11x4. The R528f kinda worries me. I have only ran it the one time but the vibration seem to be a lot between like 12k and 15k rpms. I re balanced the prop and it didn't help much. It might have been my test stand or something. I will find out when spring gets here. I think I will be happy with the power it has when I get comfortable with it.
Old 01-27-2015, 08:19 AM
  #65
MJD
MJD's Avatar
I think the R528F is just telling you that it doesn't want to be propped for those low rpm. With peak power at 32.8k rpm, the engine is obviously timed for high teens and up and I would think loading it down would produce mediocre performance results and some temperamental habits. It might run smooth but you're kinda chugging the sports car down the boulevard.
R528F
[TABLE="width: 900"]
[TR]
[TD]
Displacement: 4,66 cc
R.P.M. (max power): 32.800 RPM
Practical range: 2.000-38.400 R.P.M.
Bore x stroke: 18,35x17,60 mm
Sleeve: 3 ports
Rear ball bearings: steel
Front ball bearings: steel
Crankshaft: 14 mm
Carburetor: aluminium - 6,5mm - rotary
Glowplug: Standard Special (C6S)
Exhaust position: rear
Starting: -
Weight: 313 g
Fuel type: 10% nitro[/TD]
[/TR]
[/TABLE]
Old 01-27-2015, 09:56 PM
  #66
MJD
MJD's Avatar
Progress report for this evening: cut all new motor mount plates and doublers. This is the OS46 bolt pattern set.. Perfect fit, I found some old engine that had the same bolt pattern to test, check it out:
Get this.. the entire center assembly, with the spar stubs (3g each) is 85 grams. That's everything in the last pics except the hardware of course, with the whole thing generously CA'ed together. All plywood.
So I weighed a Hayes AS-40 engine mount to compare - 51g! I like it.
Next on the list.. OS .32, and I'll see if the NovaRossi site has the mounting info. If not.. I could use that.
ID:	2068450   Click image for larger version
ID:	2068451   Click image for larger version
ID:	2068452   Click image for larger version
ID:	2068453   Click image for larger version
ID:	2068454   Click image for larger version
ID:	2068455   Click image for larger version
ID:	2068456   Click image for larger version
ID:	2068458   Click image for larger version
ID:	2068459   Click image for larger version
Old 01-27-2015, 10:01 PM
  #67
MJD
MJD's Avatar
BTW - that is a GP 10 ounce tank.. lots of room.
Old 01-28-2015, 04:55 AM
  #68
Bonified Wingnut
Looking good! I can give you some measurements if you need them. I will try to get them later today when I get home.
Old 01-28-2015, 06:53 AM
  #69
MJD
MJD's Avatar
That would be great, I haven't looked at the Novarossi site yet to see if they have the info.
After a bit of this, I should have a database of common configurations.
Old 01-28-2015, 07:43 PM
  #70
Bonified Wingnut
This is my best measurements for the Nova Rossi's I have: 09.20/C1 .21 and the R528F are 21mm front to back and 38mm side to side. They don't appear to be 1/2 mm.
The R50F I got 21mm front to back and 45mm side to side.
I just happen to have an ASP .32 out and I am not sure if the measurements are readily available but i got 15mm and 38mm for it.
Old 01-28-2015, 08:53 PM
  #71
rcguy59
My Feedback: (8)
rcguy59's Avatar
Sounds like you've been busy, Mike. I'll be using an OS .32SX on mine. The big-block .77 can wait for the second one.
Old 01-29-2015, 07:42 AM
  #72
MJD
MJD's Avatar
I cut four sets of OS32 bolt pattern mounts last night, and set the prop driver 0.1" ahead of the nose ring. Bonified WN - the ASP should fit this bolt pattern, see below.
Running a big block requires a bit of improvisation, I don't have a CAD designed mounting scheme yet. In truth it is best to wait for a modified version for this format engine - a bit more wing, tank on CG etc. I have been sketching ideas, they will come.
This is handy info below - and the OS site has bolt patterns as well. At the Novarossi site, you can download corporate logos in various formats, and buy hats and T-shirts, but you can't get &#^%#$@ dimensional specs for the engines, only very badly translated instructions.
Here are the OS46 and OS32 bolt patterns btw. For other engine mounts I need:
A,B,C and E. I need E to locate the engine fore-aft.
Editing and cutting the plates is easy for these onesie twosies right now. For future, I will mount plate sets separate from the other parts so they can be a la carte.
Dimensional Specifications For Jett Engines
ALL DIMENSIONS ARE IN INCHES
ALL WEIGHTS ARE IN OUNCES
(25.4mm = 1" - 28.35gm=1 ounce)
TYPE DISP BORE STROKE WT* RPM RANGE A B C D E F G H J K L MBSE35 .355 .787 .730 13.8 2000-20000 1.50 .590 1.22 2.10 2.156 1.61 1.27 1.57 1.378 1/4-28 1.375 5.3SJ40 .398 .846 .708 17.4 2000-18000 1.73 .689 1.38 2.50 2.45 1.63 1.38 1.58 1.50 1/4-28 1.50 6.2
Old 01-29-2015, 08:09 PM
  #73
Bonified Wingnut
I won't be using the ASP...thats going on a foamy...lol. Probably the R50F.
I wish this was in the budget:
http://www.rcuniverse.com/market/ite...itemId=1015607
Old 01-29-2015, 09:14 PM
  #74
MJD
MJD's Avatar
Why did you have to show me that?! Oh dear, here we go again..
Old 01-30-2015, 06:45 AM
  #75
aspeed
aspeed's Avatar
Give it to Mikey, he'll try anything. That looks like a good candidate for another build thread!
