Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
No.. could it be..?
No.. could it be..?
Old 05-29-2015, 01:54 PM
  #501
rcguy59
My Feedback: (8)
rcguy59's Avatar
Originally Posted by OliverJacob
I wonder why we don't see more of these planes. Simple design, lot of speed and fun.
That's a good question and I haven't been able to figure it out either. Years ago, there was an ARF available called the "Laser Arrow". It was about 36" span and built like a tank. It was too thick to be truly fast, but it was lots of fun with a .32-.46 on it. There were 5 or 6 at our field at one time or another, including 2 of my own. A guy in our club who has an RC website (VVRC) was selling them for around $80.00 IIRC. They became unavailable one day and that was it. I also had a couple of Outlaws, one of which still exists. That was another great delta, now also discontinued. For going fast and having fun, the Demon is the best I've encountered yet. I've seen a few of the BTE deltas over the years, but not many. For a piped .91, try a 12-10 or a 13-8.
Old 05-29-2015, 02:59 PM
  #502
OliverJacob
My Feedback: (12)
Thanks, that help a lot.
The Vortex is a fun build, manual and plans are nicely done, parts fit perfectly. I am looking forward to get this in the air.
What I'd like to have is a larger SD. Hanno Prettner had some interesting designs back in the day, but they are hard to find now.
Old 05-29-2015, 03:14 PM
  #503
iron eagel
iron eagel's Avatar
The SD will lend itself to being scaled up no problem.
Old 05-29-2015, 04:33 PM
  #504
iron eagel
iron eagel's Avatar
Originally Posted by rcguy59
Been working on it again tonight. Once I test-fitted the motor, I decided to do some watt-meter pulls with some different props. Started with 4S and an APC 8-6E. 104 amps. A bit much. I must have sorted through 50 or 60 props and couldn't find anything I wanted. So I cut an APC 8-7 sport prop down to 7" diameter. I got 79.4 amps out of that one, 1131 watts. That will be my starting point until I can find some more suitable props. The LHS didn't have any, either. Figures.
Sorry I meant to mention this before...
One interesting fact I found using a data logging esc is the static draw on the ground is much higher than it is when airborne. The draw drops about 10 to 15% on average from what I have found, and if your lucky enough to get it up to the prop pitch speed the amps drop even more.
Old 05-29-2015, 06:35 PM
  #505
rcguy59
My Feedback: (8)
rcguy59's Avatar
I suspected as much. The electric version of unloading. Makes sense.
Old 05-29-2015, 08:06 PM
  #506
iron eagel
iron eagel's Avatar
Your static amp draw is going to be much higher than when the prop is not stalled. You might want to try cutting down an 8X8 down to a 7X8 just for grins and giggles. Or if your really not in love with the results that 8X7 might just work as long as you don't stay pegged the entire time. I have a very similar motor I am going to try with my one remaining 8X8 tornado prop I have left.
If you don't have a lot of love for the motor why not go for the gusto.
Regards
Paul
Old 05-29-2015, 09:00 PM
  #507
rcguy59
My Feedback: (8)
rcguy59's Avatar
I'll probably cut-down an 8-8 to try simply because I have so many of them, one won't be missed. I'm almost finished covering it now. The maiden will be Sunday or Monday.
Old 05-30-2015, 04:49 AM
  #508
MJD
MJD's Avatar
Looking forward to this one too! Ought to give a .50 a run for the money..
Old 05-30-2015, 08:19 AM
  #509
rcguy59
My Feedback: (8)
rcguy59's Avatar
I think it's probably going to be on par with a .32 glow. Wish I could have tached it but I was too busy just hanging on to it. I need to build a test stand for electrics.
Old 05-30-2015, 10:08 AM
  #510
iron eagel
iron eagel's Avatar
Good luck with the maiden.
Keep in mind when launching an electric delivers full torque from the start, so you may get a bit more of a left turn.
A test stand is not nearly as good as in-flight data, an in flight data logger will give you a lot more accurate results.
Old 05-30-2015, 03:42 PM
  #511
MJD
MJD's Avatar
At 1500w input, your power to the prop is going to be more like .46 territory I think. That's 2hp input, at let's say 80% efficiency is equivalent to 1.6hp to the prop. It will boogie for sure.
Old 05-31-2015, 06:52 AM
  #512
MJD
MJD's Avatar
I flew my old Demon with the Evo .60NX / Jett muffler yesterday. APC 9-10 prop, 10% Omega. Effortless launch, and the top speed was pretty healthy. No tracking. I would say the Jett .50 and West .50 are noticably faster, but this combo was pretty darn quick. Bit of an overcast day with intermittent rain. The vertical climb to cloudbase didn't take long.
No rocket science was done, but was interesting to see how this engine combo would fare. On a nicer day I'll fit a 10-7 or 10-8 and try a vertical release launch.
Old 06-09-2015, 11:32 AM
  #513
iron eagel
iron eagel's Avatar
Rc did you get the electric Demon airborne?
Old 06-09-2015, 12:00 PM
  #514
rcguy59
My Feedback: (8)
rcguy59's Avatar
Not yet. Last weekend was our annual Warbird Fly-in and I spent all my time getting ready for that. It is ready, though. The first few flights will be sans spinner to ensure adequate cooling.
Old 06-09-2015, 01:49 PM
  #515
iron eagel
iron eagel's Avatar
Looks good.
I know some guys with high power electrics have intake setups as part of the spinner itself.
Old 06-09-2015, 02:18 PM
  #516
combatpigg
combatpigg's Avatar
Nice job Mike..!
RCU's photo enlarger isn't working..but from what I can tell the prop looks pretty small..!
Old 06-09-2015, 02:51 PM
  #517
rcguy59
My Feedback: (8)
rcguy59's Avatar
It is, Chuck. APC 8-7 cut down to 7" dia. 1200watts.
Old 06-09-2015, 03:14 PM
  #518
combatpigg
combatpigg's Avatar
OK, now the enlarger is kicking in ........
Can you tell me where you buy those truss head screws...?
Old 06-09-2015, 03:15 PM
  #519
MJD
MJD's Avatar
There is a 7-7 in the Graupner Speed lineup, though whether it would have any advantage over this is another question. Looking forward to the flight test!
Old 06-09-2015, 03:20 PM
  #520
rcguy59
My Feedback: (8)
rcguy59's Avatar
The screws are #2 socket-head servo mounting screws. Not very aerodynamic but they were on-hand. Du-Bro sells them.
Old 06-15-2015, 03:44 PM
  #521
petec
My Feedback: (58)
petec's Avatar
Finally I had time to go down to the shop and build.....and it felt GOOD.
The 7.5 K&Bs I have are pumped so the will sit farther forward in the engine mount but that should not be a problem. I also modified the cutout for the mini servos as I have metal gear micro servos for elevons that put out 56 in/oz of torque.
Taking a quick break then back down to rip some LE material.
Old 06-15-2015, 04:01 PM
  #522
rcguy59
My Feedback: (8)
rcguy59's Avatar
'Bout time someone else got one going. My next one will have a YS45 FISE.
Old 06-15-2015, 04:04 PM
  #523
petec
My Feedback: (58)
petec's Avatar
I have a Nelson 40SS sitting here.....hmmmmmm
Old 06-15-2015, 04:56 PM
  #524
dbacque
Mine's a ways out there, still a few projects to complete first. And after reading about all the unobtanium engines you guys have, I feel like mine is going to be slow. I've only got a Jett 428 Quickie with pipe and Red Jett throttle for my SD.
But I think it'll be enough to harelip everybody on Bear Creek!
Dave
Old 06-15-2015, 05:09 PM
  #525
petec
My Feedback: (58)
petec's Avatar
Ain't nuthin' wrong with a Jett!!!!!!
