Go Back  RCU Forums > RC Airplanes > Extreme Speed Prop Planes
Reload this Page >
No.. could it be..?
No.. could it be..?
Old 05-25-2015, 02:44 PM
  #476
iron eagel
iron eagel's Avatar
His truck will, when it's done.
Old 05-25-2015, 07:59 PM
  #477
rcguy59
My Feedback: (8)
rcguy59's Avatar
Went out to the field today and got a surprise. The place was PACKED! I've never seen it that busy before. The weekend guys were there due to the holiday and the usual Monday crowd was there, too. Never had I seen that many electric foamies in one place, either. Wanna see how fast three guys can land foamies? Launch a Demon into their midst. They were all a little jumpy after that. They were really good sports about it and I restrained myself to three flights all day, It was great fun to see how many new and spectacular ways there are to separate the little beads that make up foam. I also learned that every electric airplane can have a smoke system... Once. I even saw open flames emanating from the cockpit of a DH Vampire after a smoky emergency landing. There was even a foam Demon, of sorts. I HAD to have a picture of that. One of my buddies bought Demon #1 from me today. He bought just the airframe, as he has everything else already. If someone installed some R/C gear in a toaster oven, this guy could take it up and make it look good. He was my mentor when I got into turbines, and he keeps the grounds of our field in top shape, too. Thanks, Karl. My buddy Steve got a couple of minutes of video of my last Demon flight, launch-to-landing. As soon as it's up on Youtube, I'll post a link.
ID:	2098675   Click image for larger version
Old 05-25-2015, 08:06 PM
  #478
rcguy59
My Feedback: (8)
rcguy59's Avatar
Here you go. http://www.youtube.com/watch?v=pa0jmNXeMU8
Old 05-25-2015, 08:57 PM
  #479
iron eagel
iron eagel's Avatar
Looks like you were having a blast.
Old 05-25-2015, 09:11 PM
  #480
rcguy59
My Feedback: (8)
rcguy59's Avatar
I was. I cut the flight short for the sake of Steve, the cameraman. My normal flight time is 5-6 min.
Old 05-26-2015, 06:33 PM
  #481
MJD
MJD's Avatar
Originally Posted by rcguy59
Fantastic! I'd say you're comfy with the aircraft now.
The acceleration from hand launch is surprising – light weight will do that for you.
There’s one problem with almost every Demon, happens all the time. About 15-20 seconds after the first launch, the throttle becomes ineffective, and seems to work more like a switch.You can set it low after fueling to start, then when you launch at full throttle – it just stays there the whole flight as the pilot yells "woo hoo!" and flies around like a madman for 3-4 minutes.
Old 05-26-2015, 07:32 PM
  #482
combatpigg
combatpigg's Avatar
It really looks great..!
You weren't kidding about the supply and demand situation at your field. A plane like the Demon sells itself when folks see it in person.
Your cameraman does a nice job of tracking those laps. I'll bet he's pretty good with a shotgun too.
Old 05-26-2015, 08:31 PM
  #483
rcguy59
My Feedback: (8)
rcguy59's Avatar
Don't know how he is with a shotgun, but he sure likes M-1911's. One of the many things he and I have in common. Yes Mike, mine seems to have the same defective throttle as the rest. "Start" and "Launch" are the only two settings that seem to work. They work REALLY well, though. Here we go again... Tonight I started framing up the parts I cut on the bandsaw. Note that the fwd. spar has moved aft by 1.25". That was to make room for the battery. I got a request on Sunday for a Demon set up for e-power, and I accepted the challenge. This one will be for me and the second one with any needed refinements will be for my buddy. I got a 1500W, 1600KV heli outrunner for a 6S pack. When I gutted Demon #1 to get it ready for Karl, who bought it, I laid out the e-power system on top to check placement vs. CG. Moving the spar 1.25" seemed about right. I'll know for sure in a few days. Weight should be right around 3 lbs. Please note, Mike, there are no pieces of 1/4" dowel in the spars. They go right into the ribs. Seems to work fine.
Old 05-27-2015, 04:49 AM
  #484
MJD
MJD's Avatar
Yup.. I've already started drawing in those changes.
Old 05-27-2015, 12:31 PM
  #485
Rudeboy
Rudeboy's Avatar
I've got a 1600kV outrunner for a 500 size T-rex heli in a MPX Dogfighter. I run it on 5 cells and an APC 7x10 prop. It draws well over 100 amps.
Don't know what motor you have there, but you'd need a really tiny prop to run a 1600kV motor on 6S.
If I were to put the motor I have in a delta this size, I'd be looking at an 8" prop and 4S. Probably an 8x7 or 8x8.
Old 05-27-2015, 01:56 PM
  #486
rcguy59
My Feedback: (8)
rcguy59's Avatar
Thanks Rudeboy. That's exactly the kind of advice I need. I was thinking 6.5-7" dia. and about 5-6" pitch on 6S. I was going to try 4S first, so thanks for reinforcing that idea. I happen to have plenty of 8-7's and 8-8's for my .32's. My motor is a Chinese cheapy, so I doubt it will survive 100+ amps for long. I was planning to try to hold it under 90 amps peak, as it's rated at 75. They're only about $20.00 ea., so a smoked motor here and there isn't a disaster. I've got a 150 amp ESC I was planning to use. What brand of motor are you using?
Old 05-27-2015, 08:49 PM
  #487
iron eagel
iron eagel's Avatar
Four cell and the 8/7 should be a good match, the 6.5X7 on a six cell should haul. What type of constant wattage is it rated at? You should be able to push 150% of the rated wattage for a couple of minutes anyhow with good cooling. I have done it with the cheap Out runner motors and they have held up without cooking a bearing or magnet, but they probably only have 3 or four hours each of total flight time. Stick with a real fast ESC when using a 6 pole motor (a good ESC with program limits will be able to survive frying the motor).
Edit to add:
Is your ESC a data logger that will really help you out.
Old 05-27-2015, 11:07 PM
  #488
rcguy59
My Feedback: (8)
rcguy59's Avatar
Constant wattage is 1500. This motor is 8 pole. The ESC doesn't have data logging, but I do have the programming card for it and I installed the external voltage harness to send battery voltage data back to the transmitter so that I can set up a low-voltage alarm via the telemetry.
Old 05-28-2015, 08:48 AM
  #489
iron eagel
iron eagel's Avatar
As long as you have good cooling I can't see why it shouldn't work for awhile.
Old 05-28-2015, 10:43 AM
  #490
mmattockx
That should be the motto for this forum...
Mark
Old 05-28-2015, 11:55 AM
  #491
Rudeboy
Rudeboy's Avatar
This is the one I'm using, also a chinese cheapo.
http://www.hobbyking.com/hobbyking/s...ter_Motor.html
It handles the amps just fine. Just don't keep the throttle pegged, and don't use a spinner. Or use a small spinner, but make sure that the motor windings get hit with the full speed airflow. Proper cooling keeps these things alive at 150%+ of rated power.
The same goes for the ESC. I shorten the motor and ESC wires, and solder the together, no connectors. Shortening the motor wires is a pain though, because you have to remove the lacquer from the strands
Old 05-28-2015, 12:30 PM
  #492
iron eagel
iron eagel's Avatar
Excellent advice!
Keeping the leads short is very important to minimize loss.
Another thing to consider is keeping the battery side of the esc leads as short as possible to reduce the ripple and strain on the Caps on the ESC. The shortened leads from the batter to the ESC reduces loss because of wire resistance and keeps the copper cooler which keeps the impedance lower as well. This is a major consideration with an electric motor because it is very low impedance load and any reduction in resistance anywhere prior to it make a big difference in the performance of the motor.
Old 05-28-2015, 12:31 PM
  #493
iron eagel
iron eagel's Avatar
Mark
Old 05-28-2015, 12:37 PM
  #494
Rudeboy
Rudeboy's Avatar
Charging and flying your lipo's hot also makes a remarkable difference in power delivery.
There's a reason the F5D guys are always messing with lipo heaters
Old 05-28-2015, 04:06 PM
  #495
combatpigg
combatpigg's Avatar
Mark
I am Combatpigg and I approve of this message..............
Old 05-28-2015, 07:23 PM
  #496
iron eagel
iron eagel's Avatar
Default windings and full speed airflow
Rc,
If the front of the motor isn't the front of the plane you need to have a cowl something like this (see below) to make sure the interior of the motor has airflow over the windings. You also need to vent the holes on the back of the motor into an area of low pressure to make sure it moving out well.
It is centered but I was a bit off with the camera position...
Old 05-28-2015, 09:31 PM
  #497
rcguy59
My Feedback: (8)
rcguy59's Avatar
Been working on it again tonight. Once I test-fitted the motor, I decided to do some watt-meter pulls with some different props. Started with 4S and an APC 8-6E. 104 amps. A bit much. I must have sorted through 50 or 60 props and couldn't find anything I wanted. So I cut an APC 8-7 sport prop down to 7" diameter. I got 79.4 amps out of that one, 1131 watts. That will be my starting point until I can find some more suitable props. The LHS didn't have any, either. Figures. I ditched the spinner, as it was preventing good cooling airflow. I'll finish the airplane before I do any more test runs. Here's the progress.
ID:	2099328   Click image for larger version
ID:	2099329   Click image for larger version
Old 05-29-2015, 09:40 AM
  #498
iron eagel
iron eagel's Avatar
Cool.
Old 05-29-2015, 11:56 AM
  #499
OliverJacob
My Feedback: (12)
I wonder why we don't see more of these planes. Simple design, lot of speed and fun.
Right now I am building a BTE Vortex and will put an OS 91 FX with a Macs pipe on it. This won't be crazy fast, but good enough to get my feet wet and
then move on to faster deltas. Does anybody have recommendation on the prop size for this?
Years ago I build a SD and wasn't quite ready for it, so the Vortex is my delta trainer.
And I have that pulse jet engine sitting on the shelf...
Old 05-29-2015, 12:39 PM
  #500
iron eagel
iron eagel's Avatar
You will have to talk to MJD about that.
